NSA325 RAID1 lost
Hello everyone,
I lost my RAID1 on 2 HDD, 4Tb.
- Both HDD are 4Tb, WD. I've got red indicator on 2nd (right side) few times, and only one on 1st (left side) during data coping.
- About one week ago I switched off NAS and start inspection of each HDD by Victoria program. I connected 2nd faulty and found a lot of BadSectors on it.
- I am afraid that 1st HDD has the same problem, I recided to inspect 1st HDD as well but in red-only mode. I found no issues.
- I put 1st HDD in NAS on its proper left side and put used clear HDD in right side
- When NAS have started I found nothing. No RAID volume. I put all HDD to initial state (see item 1) and start investigation
- telnet logs :
~ $ cat /proc/partitions
major minor #blocks name
7 0 143360 loop0
8 0 2930288567 sda
31 0 1024 mtdblock0
8 16 3907017527 sdb
31 1 512 mtdblock1
31 2 512 mtdblock2
31 3 512 mtdblock3
31 4 10240 mtdblock4
31 5 10240 mtdblock5
31 6 48896 mtdblock6
31 7 10240 mtdblock7
31 8 48896 mtdblock8
~ $ cat /proc/mdstat
Personalities : [linear] [raid0] [raid1]
unused devices: <none>
~ # mdadm --examine /dev/sda
mdadm: No md superblock detected on /dev/sda.
~ # mdadm --examine /dev/sd?
So, what is the better way to restore my data?
I suspect that during inspection windows cut my 1st HDD (right) or did other changes.
I am going to restore partitions by testdisk app (risk to crash partitions) or install Linux and mout 1st HDD in it (slow, need to install Linux and copy 3tb of data somewhere). Do you have any idea how to fix it?
So, I've started to search how to fix the issue, and performed few experiments on Debian and broken (badsectors) HDD. I coudn't get any progress in it, because md0 is not working there
But I found thread here in Zyxel community how to start GNU Parted 3.0 for my GPT (not MBR) HDD. As far as I alredy knew consequnces (no), I did little fix of backup GPT table
~ # parted /dev/sda
GNU Parted 3.0
Using /dev/sda
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) select /dev/sda
select /dev/sda
Using /dev/sda
(parted) print
print
Error: The backup GPT table is not at the end of the disk, as it should be.
This might mean that another operating system believes the disk is smaller.
Fix, by moving the backup to the end (and removing the old backup)?
Fix/Ignore/Cancel? Fix
Fix
Warning: Not all of the space available to /dev/sda appears to be used, you can
fix the GPT to use all of the space (an extra 1953460034 blocks) or continue
with the current setting?
Fix/Ignore? Fix
Fix
Model: 1 WD4000FYYZ-01UL1 (scsi)
Disk /dev/sda: 4001GB
Sector size (logical/physical): 512B/512B
Partition Table: gptNumber Start End Size File system Name Flags
1 1049kB 512MB 511MB ext2 mitraswap
2 512MB 4001GB 4000GB eexxtt44So after reboot, it started as "Degreded" and all I need is "Rebuilt"
Special thanx for Mijzelf, he showed me right directions!
at this moment I found that I've got HPA on one or both HDD and LBA is limited 3Tb meanwhile it's 4
major minor #blocks name7 0 143360 loop0
8 0 2930288567 sda
31 0 1024 mtdblock0
8 16 3907017527 sdbIf disk sda is really 4TB, it's shot. The kernel only detected 2.9TiB, which means the disk reported that. Disk sdb (and also sda) has lost it's partition table. Have a look with 'dmesg', to see if there are I/O errors.
If there are no I/O errors on sdb, (or a least not in the beginning of the disk) you could try a tool like Testdisk, to see if it can repair your partition table. If there are (a lot of) I/O errors, it is a better idea to first create a bitwise copy on a new disk, using a tool like ddrescue, and try to repair the partition table/raid array/filesystems on the new disk. (Every write action to a disk having I/O problems can make the problems worse).
Mijzelf, thank you for your qiuck response and really useful advice. I already thought about sector-to-sector copy because I don't want to loose data.
I confirm that, testdisk found the issues, but couldn't restore partition because of critical errors. Anyway I am going to write something only when I will have bitwise copy. BTW sda works great as device but has a broblem with partitions. I have one idea, which based on article Dmitry Postrigan (HDD expert), at least I have the same simptom - I lost 1Tb when I connect 4Tb HDD to PC with Gigabyte Mainboard.
byThank you, let's keep in touch
Hello, Mijzelf and everybody
So, I was right and it was HPA issue. I did all things by manual above and restored factory HDD capacity. I can't mount it when I boot from Linux emergency CD, but TestDisk shows green partitions
Now here is a new log when I install left (L,0) HDD and removed faulty right (R,1)
major minor #blocks name 7 0 143360 loop0
8 0 3907018584 sda
8 1 498688 sda1
8 2 3906518016 sda2
31 0 1024 mtdblock0
31 1 512 mtdblock1
31 2 512 mtdblock2
31 3 512 mtdblock3
9 0 3906516856 md0
md0 : active raid1 sda2[0]
3906516856 blocks super 1.2 [2/1] [U_] ~ # mdadm --examine /dev/sda?
mdadm: No md superblock detected on /dev/sda1.
/dev/sda2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 7afec152:2f275434:4ddd592f:ba3ffc9c
Name : NSA325:0 (local to host NSA325)
Creation Time : Sat Apr 9 16:25:25 2016
Raid Level : raid1
Raid Devices : 2 Avail Dev Size : 3906516992 (3725.55 GiB 4000.27 GB)
Array Size : 3906516856 (3725.54 GiB 4000.27 GB)
Used Dev Size : 3906516856 (3725.54 GiB 4000.27 GB)
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : clean
Device UUID : 8bb39033:1543e6d4:d7eb48b8:fd740f36 Update Time : Mon Dec 4 19:12:24 2023
Checksum : b6b8ce66 - correct
Events : 22514 Device Role : Active device 0
Array State : AA ('A' == active, '.' == missing)
mdadm: cannot open /dev/sda3: No such device or addressAs for me it looks good but Volume status is down. Capacity=N/A, Command 'Scan' of the volume in Web-interface said 'Failed to scan volume.'
Is the array mounted?
cat /proc/mounts
If not, can you mount it manually?
mkdir /tmp/mountpoint su mount /dev/md0 /tmp/mountpoint
Mijzelf, hello. No it isn't. I mount as you write and now here is tmp point and FS is ext4
~ # mount /dev/md0 /tmp/mountpoint
~ # cat /proc/mounts
rootfs / rootfs rw 0 0
/proc /proc proc rw,relatime 0 0
/sys /sys sysfs rw,relatime 0 0
none /proc/bus/usb usbfs rw,relatime 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
/dev/mtdblock8 /zyxel/mnt/nand yaffs2 ro,relatime 0 0
/dev/sda1 /zyxel/mnt/sysdisk ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /ram_bin ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /usr ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /lib/security ext2 ro,relatime,errors=continue 0 0
/dev/loop0 /lib/modules ext2 ro,relatime,errors=continue 0 0
/dev/ram0 /tmp/tmpfs tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/etc tmpfs rw,relatime,size=5120k 0 0
/dev/ram0 /usr/local/var tmpfs rw,relatime,size=5120k 0 0
/dev/mtdblock4 /etc/zyxel yaffs2 rw,relatime 0 0
/dev/mtdblock4 /usr/local/apache/web_framework/data/config yaffs2 rw,relatime 0 0
/dev/md0 /tmp/mountpoint ext4 rw,relatime,barrier=1,data=ordered 0 00 -
Well, in that case I don't know why your volume is down. Normally that means that either the raid array could not be assembled, or the filesystem couldn't be mounted. But in your case both can be done. So maybe reboot and then look in kernel log (dmesg) if there is any error which shines a light on this case.
Hello everybody. I'm still fighting with it… Looks like a problem which I'm going to reslve/
GPT:Primary header thinks Alt. header is not at the end of the disk.
GPT:5860577133 != 7814037167
GPT:Alternate GPT header not at the end of the disk.
GPT: Use GNU Parted to correct GPT errors.
sda1 sda2
sd 0:0:0:0: [sda] Sector size 0 reported, assuming 512.
ehci_marvell ehci_marvell.70059: irq 19, io base 0xf1050100
sd 0:0:0:0: [sda] Attached SCSI disk
ehci_marvell ehci_marvell.70059: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choiceJust for information
~ # parted /dev/sda
GNU Parted 3.0
Using /dev/sda
select /dev/sda
Using /dev/sda
(parted) print
print
Fix
Fix/Ignore? Fix
Fix
Where does that info come from? That address 7814037167 might point to the sector where the 2nd copy of the GPT should be located. (It's at around 4TB at a sectorsize of 512). But then that 5860577133 is an address which points to the end of a 3TB disk.
So the GPT interpreter here seems to look at a 3TB disk having a 4TB GPT, or vise versa.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
