Guest network in bridge mode?
MarkRS
MarkRS Posts: 13 image  Freshman Member
First Answer First Comment Second Anniversary
I have three AX1800 units, one connected to the internet router (do many/any domestic installations have a "bare" modem these days?) and the other two connected by WiFi.
The "guest" network seems to have disappeared. I did have NAT mode set initially, which is perhaps when I saw the guest network. Does it not work in bridge mode ()?
The manual (yes, I looked) says go to the WiFi page from the home page of the app and simply enable the guest network, but it is not there to be enabled in my app.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,388 image  Zyxel Employee
    edited November 2023
    Hi @MarkRS
    The Guest Wi-Fi Network is not available in bridge mode.
    For more information you can refer to User Guide Pg 138
    https://www.zyxel.com/global/en/support/download?model=multy-m1-wsm20
  • MarkRS
    Thanks for that Jerry, I'm not sure how I didn't see that.
    So how do I provide a guest network? My Multy M1 router is (ethernet) connected to a (Zyxel) VMG3925-B10B, currently I've got its WiFi turned off. I know it can provide a guest network, but will this interfere with the Multy WiFi?
  • Zyxel_Jerry
    Hi @MarkRS
    Since you're using bridge mode, the guest wifi network is not available, if would like to use the guest wifi, it required to change to router/NAT/standard mode.
