Smarthome use GS1900-24E = Impossible .... 😤
  • QTT1
    QTT1 Posts: 25 image  Freshman Member
    Also Nothing changes if I choose any of these options :
  • QTT1
    Done the unplug and reset button 10 sec ….. nothing changes…
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @QTT1,
    Could you help to record a video for the questions below? Since the information you provided was vague, it would be clearer with the video.
    I would like to clarify with you:
    3. Can the PC ping to the switch (192.168.1.1) when it has a wired connection to GS1900? image (2).png
    4. If you can ping to the switch, can you access 192.168.1.1 via web GUI? image (5).png
    5. If you cannot ping to the switch, please open the ZON utility, and change the Network adapter in settings to Realtek Gaming 2.5G Family controller which I assume should be the wired NIC of your Windows PC. And click the rescan button to scan the Zyxel device again. image (4).png image (6).png
    Please provide the shared link of your video in the private message we last used, thanks.
    Zyxel Melen
  • QTT1
    1. its green. How ever these photos dont say:
    So just to be sure should I connect the computers ethernet, TP-link DECO or Starling ethernet on port 1 ?
    If ill take the cord from Starling Ethernet port the internet dies or should it be alive if the ethernet cable from computer is meant to go on that port 1
  • QTT1
    PS.
    There isnt such ….(see pic.) which One of these
    Here is the options …
    the 192.168.1.1 goes to Starlink
  • QTT1
    The 192.168.1.2 and 255.255.255.0 cant be accesed
    PeterUK Posts: 4,418 image  Guru Member
    Your really making hard work over something easy I don't know how your not doing this correctly
    You have a switch nothing else connected to it but PC reboot the switch in windows networking set your NIC with a fixed IP 192.168.1.2 subnet 255.255.255.0 you should then be able to connect to the switch at 192.168.1.1 which you should likely need to change.
  • QTT1
    Peter ….. you might have attitude problem that isn't good IF you answer customers questions when YOUR product DOSENT WORK please take a look on the mirror on that answer mind how you would read it as Zyxel customer support !!!
    Easy ….. this isn't ….. normal plug & Play is the way like the TP-link that I have here now working ….
    ONCE AGAIN  1. should I connect the computers ethernet port on zyxel port 1 = NO INTERNET ?
    2. Zyxel port 1 to TP-link DECO
    3. or Starling ethernet on Zyxel port 1 ?
  • QTT1
    so ”PeteUK” here is the results after Ethernet cabel to zyxel
    so ”it ISNT so easy” to get this switch One use three weeks and still counting ….
  • Zyxel_Melen
    Hi @QTT1,
    I understand your concerns with the GS1900-24E setup. To directly address your question, please connect your PC directly to the GS1900 using its Ethernet port. Avoid connecting the TP-Link Deco or STARLINK for now.
    This step will help us confirm the switch's functionality.
    In addition, please refer to the screenshot below. I have marked the correct NIC for you.
    Your cooperation in this diagnostic process is much appreciated.
    Thanks.
    Zyxel Melen
