IPv6 static IP with Nebula Orchestrator
GiuseppeR
GiuseppeR Posts: 451  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
here in Italy there are some ISPs that are offering web connections with static IPv6 so the question is: could Nebula Orchestrator use this static IPv6 to establish strong VPNs?
Is there a specific setting to enable?
Thanks in advance
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @GiuseppeR,
    Could you provide a page screenshot for us to confirm which function or product you hope for? Because we have Nebula Orchestrator and VPN Orchestrator in the Nebula control center.
    Zyxel Melen
  • GiuseppeR
    edited December 2023
    Hi @Zyxel_Melen
    I was referring to Nebula VPN orchestrator.
    Anyway the question is also related to Site-to-Site VPN and Remote access VPN generally speaking:
    is a static IPv6 usable for connecting via VPN?
    I only used IPv4.
    At your disposal, see you soon.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,435  Zyxel Employee
    Hi @GiuseppeR,
    IPv6 is not supported on Nebula VPN orchestrator.
  • GiuseppeR
    Hi @Zyxel_Emily
    is there a plan to support it in Nebula VPN orchestrator?
    If I decide to use Zyxel firewalls on premise mode, is there a support of IPv6 for VPN connections?
    See you soon
  • Zyxel_Emily
    Hi @GiuseppeR,
    We have no plan to support IPv6 on Nebula Orchestrator.
    You can configure IPv6 on web GUI and use Cloud Monitoring Mode to manage on-premises mode device on Nebula. Here are some articles for your reference.
Nebula Tips & Tricks
