[NEBULA] Guest network question
Hello @JKoppen
The easiest way is to create another site and add one AP there with guest network enabled.
But if both APs have to be on the same site, then you'll need to use "tagging" (not to be confused with VLAN tagging).
You can find more about that here:
https://businessforum.zyxel.com/discussion/756/how-can-i-configure-to-separate-ssids-between-naps#latest
What you'll need to do is tag one AP with something like "With_Guest", then add this tag on the SSID with Guest Network enabled.
This will enable both Private and Guest SSID on my NAP303.
While enabling only Private SSID on my NAP203.
Cheers,
Barney6
Hello @JKoppen
Cheers,
Barney6 -
Great!
This was indeed what I was looking for.
Thank you for your reply
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
