vmg3006-d70a can not update firmware
Chr1s4us
Chr1s4us Posts: 5 image  Freshman Member
edited November 2023 in Home Router
I have a vmg3006-d70a which is still having the initial firmware. With that given, I can not add the necessary vlan 7 tag. I already tried to update the firmware update, but the device is not accepting the update. Even after a reset.
Can you provide me the firmware for 2020, or is there another option to force a firmware update?
  • Chr1s4us
    I was able to help myself.
    DO THIS ONLY WHEN YOU KNOW WHAT TO DO! YOU CAN DESTROY YOUR DEVICE!
    1. I opened up developer mode:
    http://modem_ip/webng.cgi?sid=auto&controller=WebConfig&action=hiddenDevActivation
    2. Activate ssh. Hint: You have to setup a password for this user and set up the network, which should be allowed to connect.
    3. Bring the firmware you want to install to the device - there is no SCP available:
    cat firmware-zyxel-vmg3006-d70a-v17.39.17.1/ZyFW-17.39.17.1-2022-01-06.img | ssh admin@192.168.100.1 "cat > /tmp/ZyFW-17.39.17.1-2022-01-06.img"
    4. Verify the checksum! I used md5sum which is fine for me!
    5. Upgrade firmware:
    /bin/web_upgrade -d -r -m /tmp/<firware-file>
