automatic restart LTE7240-M403
Zoggo
We are using a LTE7240-M403 as LTE-Router for the remote serivice of our heating system. Unfortunately this router lost connection to the internet every 2 or 3 weeks. So I like to add a script by ssh/telnet which restart the router by himself if he lost connection to the internet. Is this possible?
I think it is possible.
But I dont know the exact command.
You can use telnet to login and periodically use command to know the connection status.If it disconnect, then sent out the command to reboot.
Hello, yes, it is possible to add a script to automatically restart your LTE7240-M403 router if it loses connection to the internet.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
