GS1100-16 strange port behaviour
Hi @RCTechCon ,
Welcome to Zyxel Community!
According to your description, I would like to check the following with you:
1. You mentioned you use 20 of 24 ports on the Switch, may I assume your Switch is GS1100-24 or GS1100-24E?
2. May you provide me the first 5 letters of the serial number? We would like to know the production year.(It should start with "S")
3. May you share what devices are connected to your Switch? Do you also connect Unifi AC Lite like other users mentioned above? What is the application in your daily use?
4. Is there any new device or new application you use in the network recently? The reason I ask this is because you mentioned the Switch has been working well for a year.
Thanks.
Jason0 -
I have a similar problem with the GS1100-16. The port to which an AVM Repeater 1200 (firmware 7.50) is connected seems to hang up every few days. The LEDs are flashing, but the port is dead and won't work again until I've powered down the GS1100. I have already tested several ports and the problem moves with them.
Hi @Thor78,
Welcome to the Zyxel community!
This is likely due to a broadcast storm or loop since you mentioned the "LEDs" but not "LED".
Could you share your topology for better clarification?
Have you checked if other devices with the cable connection can ping each other when this happens?
If you cannot ping each other means your network has a broadcast storm or loop. Finding out where the broadcast storm or loop comes from is a good start to solving this problem.Zyxel Melen0 -
Hi @Thor78,
Furthermore, you can also isolate the GS1100 with two PCs to verify whether it will stop working after a few days or not.
If it won't, then this might be due to your network surrounding.
Zyxel Melen0 -
I didn't mean all LEDs. Only the LED of the affected port was meant. Only the one port to which the AVM Repeater 2400 is connected as an AP is affected. The other ports and devices continue to function and are pingable. I will deliver the network topology later.
Hi @Thor78,
Thanks for the more detailed information.
Since you mentioned other devices are functioning, I would like to check the following with you:
- Try to ping the AVM Repeater 2400 when the issue happens.
- Replug the Repeater.
- Disconnect the AVM Repeater 2400 and connect another device to test that port's functionality.
Thanks.
Zyxel Melen0 -
Topology
I will report when the issue happens next time.
Hi, I have same issue as OP: GS1100-16 with UniFi AC Lite connected to one port. Steps I did:
- Firstly I have AC Lite connected to port 16 - then this issue of disconnection showed
- Then connected to port 14, and after while, issue showed again - restart
- Today this issue on port 14 with AC lite happened again
- without restarting switch, AC Lite plugged to port 16 - AC Lite connected - ping working
- LED on port 14 stay light up
- Reconnection AC Lite to port 14 - connection lost again - no ping
- LED on port 16 off
- Reconnection AC Lite to port 16 - connection working - ping working
- Connected Raspberry Pi 4 to port 14 - no ping - just Ethernet LEDs on Raspi blinks once in 3-8 sec
- Connection on all other ports working
- On port 15 is connected another device through POE injector: NanoBeam 5AC and never was problematic like AC Lite
AC Lite is running OpenWRT, but issue persist through multiple versions.
Hi @kumen,
- without restarting switch, AC Lite plugged to port 16 - AC Lite connected - ping workingLED on port 14 stay light up
- Reconnection AC Lite to port 14 - connection lost again - no pingLED on port 16 off
To better clarify your problem related to hardware, could you help to connect a loop, port 14 connects with other ports, and check if the port LED flashes rapidly? This test requires other devices to be connected to the switch as well. Thanks in advance.
Zyxel Melen0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
