GS1900-24 - Latest firmware: Importing p12 certificate fails with error 0x246
zyste
zyste Posts: 4 image  Freshman Member
Hello, I'm trying to import a p12/pfx file generated using the following command:
openssl pkcs12 -export -out switch.pfx -in switch.crt -inkey switch.key
on a GS1900-24 switch (Rev. A1, Firmware V2.80(AAHL.0) | 10/16/2023).
However, it always fails with the following alert (see image below too):
Upload certificate failed. Unspecified error(0x246)
I tried several things now but can't get it to work.
Any ideas?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,650 image  Zyxel Employee
    Hi @zyste,
    Thanks for your kind correction. Please allow me to rephrase my previous explanation. After checking I found that GS1900 only supports the RSA algorithm but not the ECDSA algorithm. Could you generate an RSA algorithm certificate file and import it to GS1900?
    Zyxel Melen
  • Zyxel_Melen
    Hi @zyste,
    Could you share the certificate with me? I will try to reproduce it on my side. Please check the private message I sent to you and provide the certificate and its password there.
    Zyxel Melen
  • zyste
    Hello @Zyxel_Melen, I sent you the p12 file via PM.
  • Zyxel_Melen
    Hi zyste, thanks for the file! I will test it next week and keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    Hi @zyste,
    After checking, I found that GS1900 only supports .pfx file but not .p12 file. Could you generate a .pfx file and import it to GS1900?
    Zyxel Melen
  • zyste
    Hi @Zyxel_Melen,
    I think there's a technical misunderstanding on your side - pfx and p12 is essentially the same thing, just the extension is different. So, you'd just have to rename the file to e.g. certificate.pfx
    As far as I remember I tried that too but got the same error - as reference, see the extensions at the Wikipedia page.
    https://en.m.wikipedia.org/wiki/PKCS_12
  • Zyxel_Melen
    Hi @zyste,
    Zyxel Melen
  • zyste
    Hello @Zyxel_Melen,
    thank you for the hint - I used RSA and now it indeed worked!
    As a suggestion, a better error message in a future firmware release would be really helpful - or at least an explanation of what error 0x246 means somewhere on the Zyxel knowledge base or similar.
    Discussion closed - thanks again for your help and have a nice day!
  • Zyxel_Melen
    Hi @zyste,
    Thanks for your input. We have already discussed this part and recorded it in the enhancement checklist. Stay tuned for our future firmware release.
    Zyxel Melen
