NSA325 Share permissions
I have a strange problem accessing user created shares on my old NSA325 ( I know it is no longer supported but it was doing the job).
From Windows 11 (and Wind 10) I can not access any user created shares on the device, I can access the built-in shares, music, video, etc.
If I try to map a network drive it fails with the "check spelling" error.
I have the Entware-ng samba server installed and running.
As well as moving to Windows 11, I have made quite a lot of changes to my home network, went from powerline adapters to wi-fi mesh, so that may have something to do with it.
Make sure the privileges on the shared folder. For any spelling errors, consider using simple naming to check for potential issues.
I have checked permissions and spelling. The permissions are the same as the built-in shares which I can access
I can think of several reasons why those shares don't work. The Entware samba uses /opt/etc/smb/samba.conf, or something like that, while the firmware generates an /etc/smb/samba.conf. To copy with that, /opt/etc/smb/samba.conf has to include /etc/smb/samba.conf (or you have to maintain the conf file yourself). So have a look if that is the case. And have a look if there could be something in /etc/smb/samba.conf between the build-in shares and the user created ones, which could somehow 'end the include'.
Another thing is login. The samba passwords are stored in /etc/smb/smbpassword or something like that. I don't know where Entware samba looks for them. It could have it's own file, in which case all 'firmware' passwords are wrong. Maybe the file /opt/etc/smb/smbpassword was a symlink to the firmware one, and somehow the symlink is exchange by a copy of the firmware file at some point in time.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
