I can't open the network folder
with my new nas326
and then…
Whatsup?
Thank you.
Looks like you may have to start the setup procedure again, or at least try to login using the web page http://nas326 (see your user manual) and configure your shares. Difficult to say what has happened to your original configuration, so you need to check and maybe set up your configuration again like the first time.
(in case your PDF manuals are missing)
All the shares are available,I dont understand what can be.I will try to start setup procedure…again.
Thank you,see you soon0 -
but,where is the setup procedure? It will erase all my files on hd ?
I don't know this product personally, so my suggestions will mostly be generic, until someone with direct experience can post more exact procedures.
I assume there should be some kind of app to edit your existing configuration, where you can change the passwords or even username and passwords, if necessary. Your issue seems to be that there is a problem entering correct password or username (or both).
My preferred action would be to locate the setup for your shares in the web GUI and reset the password (or username + password) to get the access working again.
- 211 Nebula Ideas
- 544 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 465 News and Release
