Telenor Zyxel NR7101
Hello! I rented a house that has a telenor nr7101 router installed and I would like to use it, but I can't find the sticker with the wifi/admin passwords, and I don't know exactly how to set it up.
Please help me if you can.
Thank you very much!
The NR7101's Wi-Fi is for installation and local management, it does not route to the Internet.
There should be an indoor router connected to the NR7101; the indoor router is to provide wired and Wi-Fi access. Please have a look if there's an indoor router there; and access the Internet first by connecting to the indoor router, either by wire or wireless.
Check if there's a sticker showing the indoor router's Wi-Fi password, or you may have to contact Telenor for support since they have better overview of each model's credentials and usage.
Regards,
Bob
Regards,
Bob
Tank you!
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
