Assign WAN connections to specific LAN ports and WIFI in Zyxel VMG3625-T50B?
Can I use bridged and routing VDSL2 WAN connections simultaneously in Zyxel VMG3625-T50B modem/router?
I want to connect 2 LAN ports to bridged WAN and the rest LAN ports and the WIFI to routed WAN connection. Is this possible?
Yes it is in "Interface Grouping"
I have one PPPoE connection for the zyxel device at VLAN 835, one bridge connection for a second router at the same VLAN on LAN1, IPTV on VLAN 836 at LAN4 and another interface for VoIP at VLAN 837.
Notice that for each Interface Group you need to go at Home Networking and assign Default router Ip and DHCP enable/disable.
Well, RTFM is what I should've done a bit more before hitting the forums, but the answer was in the chapter 17 of the device's manual, Interface grouping.
I can create an interface group where I assign specific WAN interface to a certain group of LAN ports, including the WIFI.
Maybe someone with the same question finds this answer useful.
- Trokari1 -
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 489 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
