NR7101 pierde la conexión cuando el proveedor me asigna una nueva dirección wan ip
Lory_
i just installed my antenna, i noticed that when my internet provider changes my ip address on the wan side as it is for all private internet networks, i lose connection for a moment.
are there specific settings to avoid this ?
Normally when ISP issue a new IP. It will natually disconnect for a moment to change the IP.
Here is a question that how long will the disconnection happen. If it reconnect in the short time then it is the normal behavior.
If the disconnection will cause you trouble, maybe you can ask the ISP to change IP in the late night.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
