FWA510 external antenna conection - do I need to connect all four?
Hello, just bought the FWA510. In the manual there seems to be two external antenna connectors but on the box itself there are actually four. Do I need to connect all four, or which ones?
Hi @JonasB
Our user's guide is a general guide applicable to various Nebula Mobile Router models, some of which have only two external antenna connectors. However, the FWA510 model, which you've purchased, comes equipped with four antenna connectors.
For optimal performance, it is recommended to connect external antennas to all four connectors. This configuration enhances signal strength and overall connectivity.
(Note: To enable the external antenna, please ensure that the INT/EXT switch on the device is set to EXT.)
Kay
Hi @JonasB
Kay
And which antenna connector goes where? My Poynting XPOL-24 4X4 5G/LTE MIMO Antenna cables are labeled:
ANTENNA 1 MAIN
ANTENNA 1 AUX/DIV
ANTENNA 2 MAIN
ANTENNA 2 AUX/DIV
Or does it not matter where you connect them?0 -
Hi @Hcan
For optimal performance, we recommend using full-band antennas on all external connectors. All of them are identical, providing a more efficient configuration.
Here are the hole positions for our antennas from top to bottom, supporting the specified frequency bands. You may review and select them accordingly:
Port
Frequency
ANT0(main)
703MHz-4200MHz
DRX
703MHz-4200MHz
MIMO3
1710MHZ-4200MHz
MIMO4
1805MHZ-4200MHz
Kay
- 434 Beta Program
- 2.6K Nebula
- 172 Nebula Ideas
- 404 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
