Help With Login Portal
Hi everyone,
I managed to fix it! T-Mobile has (for the business users) a portal were you can manage your settings. However, you cannot change all settings. So I found a workaround.- Download Google Chrome (Other browsers with strict policies, didn't seem to be working)
- Go to your routers IP. In my case it is http://192.168.0.1 (IMPORTANT: Use HTTP)
- When you are on the Connection Refused page, hold the back arrow. (IMPORTANT: Don't click it, hold it.)
- Select the option that says "Welcome to the web base configurator". (The previous page)
That fixes it in my case. If it doesn't for you, you can continue this tread.
- 441 Beta Program
- 293 Service & License
