NR7101 IP Passthrough issue in 100ABUV8C0
Hello
got NR7101 with V1.00(ABUV.7)C0 and RG502QEAACR13A02M4G_ZYXEL.
I run it with IP Passthrough mode. Had to create manually the Group interface containing Cellular WAN 1 and LAN1 interfaces together. Otherwise, when I push the "IP Passthrough" mode under "APN configuration" it says that i have to make sure that corresponding interface group is created.
So the issue is when I upgrade to 100ABUV8C0, the IP Passthrough mode doesn't work anymore, my second router gets IP from 192.168.2.0/24, my created group interface disappears and there is new CELL type interface with that group interface name created under Network - Broadband menu (right after Cellular WAN 1 and Cellular WAN 2 interfaces).
just upgraded to 8 and made new screens of that interface. And the is no group interface anymore also.
If i reset to factory using 8 version and create the group interface again, IP Passthrough works but only until I restart the router. Then it comes again - no group interface, new CELL interface and no internet connectionю And I am not allowed to save any changes to this new CELL interface. Can't delete it also. Can't break group interface also, as it disappears.
Any thoughts?
it was ZY config issue. after I requested config from ISP it is ok now
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
