Settings for 802.1p Priority in Nebula
Best Answers
Hi @Niro96,
You can assign a specific VLAN for these individual IP addresses and set the quality of service for this VLAN to achieve your purpose. If these individual IP addresses are assigned to the devices with the same OUI, you can use vendor ID based VLAN for this task.
Zyxel Melen0 -
Ok. Thank you.
greeting Marcus
Hi @Niro96,
In addition, when the switch is in cloud mode, you can change the port priority on the local GUI. For specific IP addresses, please reference the above suggestion.
Zyxel Melen0
Hi @Niro96,
Currently, Nebula does not support 802.1p on the switch port setting page. But you can configure 802.1p on Site-wide > Configure > Switches > Switch settings page.
Please reference the options below:
- Quality of service
- Voice VLAN
LLDP-MED:
OUI:
- Vendor ID based VLAN
Hope it helps.
Zyxel Melen0 -
Thank you for the info. Can I then prioritize individual IP addresses/ports? With Vendor ID based VLAN? greeting Marcus
Hi @Niro96,
Zyxel Melen0 -
Ok. Thank you.
greeting Marcus
Hi @Niro96,
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
