Settings for 802.1p Priority in Nebula
Niro96
Niro96 Posts: 56 image  Ally Member
edited January 2024 in Nebula
Is there a way to configure the priority of the GS1920 ports in Nebula?
greeting
Marcus
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,632 image  Zyxel Employee
    Hi @Niro96,
    You can assign a specific VLAN for these individual IP addresses and set the quality of service for this VLAN to achieve your purpose. If these individual IP addresses are assigned to the devices with the same OUI, you can use vendor ID based VLAN for this task.
    Zyxel Melen
  • Niro96
    Ok. Thank you.
    greeting Marcus
  • Zyxel_Melen
    Hi @Niro96,
    In addition, when the switch is in cloud mode, you can change the port priority on the local GUI. For specific IP addresses, please reference the above suggestion.
    Zyxel Melen
  • Zyxel_Melen
    edited January 2024
    Hi @Niro96,
    Currently, Nebula does not support 802.1p on the switch port setting page. But you can configure 802.1p on Site-wide > Configure > Switches > Switch settings page.
    Please reference the options below:
    • Quality of service
    • Voice VLAN
      LLDP-MED:
    OUI:
    • Vendor ID based VLAN
    Hope it helps.
    Zyxel Melen
  • Niro96
    Thank you for the info. Can I then prioritize individual IP addresses/ports?
    With Vendor ID based VLAN?
    greeting
    Marcus
  • Zyxel_Melen
    Hi @Niro96,
    Zyxel Melen
  • Niro96
    Ok. Thank you.
    greeting Marcus
  • Zyxel_Melen
    Hi @Niro96,
    Zyxel Melen
Nebula Tips & Tricks
