CHANGE PHP IN PHPMYADMIN IS POSSIBLE??? (FFP-METAREPO-UPDATE WEB_PREFIX)
nick11
nick11 Posts: 8 image  Freshman Member
edited January 2024 in Personal Cloud Storage
Change dir /i-data/ddd8f3c9/.PKG/phpmyamdin/php
In this dir /i-data/ddd8f3c9/.PKG/ffp/ffproot/ffp/DIRPHP(8.0-FOR MY)
And modify all file php in last verisn to load in php new
Note: NAS326 LAST FIRMWARE 5.21 ECC…
@Mijzelf What do you thinks??
Ps: I follow this link
  • Mijzelf
    Mijzelf Posts: 3,063 image  Guru Member
    I think it won't work, as long as you use the firmware webserver. The reason is that the firmware webserver (apache) has some php stuff compiled in, which has to be binary compatible with the used php version.
  • Mijzelf
  • Olek1Romamyk
    Olek1Romamyk Posts: 2 image  Freshman Member
    Instaluje wersje php tą 009 fw4 na NAS326 5.21v ale wyskakuje błąd i nic nie moge zrobić czy jest szansa na zainstalowanie php w 2026 roku na tego nasa
  • Mijzelf
    At least for the '326 you'll have to use fw5 packages.
