NWA50AX PRO & NWA50AX
edited January 2024 in Nebula
Having issues with two NWA50AX & one NWA50AX PRO, recently this started where they continuously go off line and back online. This is causing devices to redirect to another AP online or disconnect completely of all three AP's go off lines. Tried reviewing all the config and community support but no resolution.
Screenshot 2024-01-09 at 15.58.37.png Screenshot 2024-01-09 at 15.58.16.png Screenshot 2024-01-09 at 15.57.35.png Screenshot 2024-01-09 at 15.56.25.png
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
  • Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hello @AndyFish
    Please check the Cloud Control Status as below screenshot and share with us. Below is the FAQ for your reference:
    How to check the Cloud Control Status when AP is offline on Nebula?
    Besides, please check your firewall rule or ISP whether they allows below Nebula services:
    Nami
  • Hello Nami,
    Thanks for looking into this, on checking I do see the issue that the internet fails on the CCS.
    When it reconnects all is show ok again.
    I am checking the Firewall settings, at the moment I turned it off.
  • I have checked the firewall settings on the virgin media hub 5 and there are no options to set these up. the firewall is turned off. I did find virgin media has turned on the some default web safe options, I have now turned these off. but the problem still persists.
    edited January 2024
    Hello @AndyFish
    I've reviewed the status of your site and noticed that the 3 APs have been consistently online since 19:00 (GMT+8) and remained stable until my last check.
    To ensure that everything is functioning optimally, could you please confirm if the issue you were experiencing has been resolved?
    If there are any further disruptions, do let us know so we can provide additional assistance.
    Nami
  • Hello,
    I can confirm all is resolved, I found that virgin media ISP was the issue. Where I was unable to use the Virgin Hub 5 so replaced with another router which allowed DNS configurations. Since making this change the AP's are running great.
Welcome!
Welcome!
Nebula Tips & Tricks
