Problem rebuilding RAID1
I have had a RAID1 array on my NAS520 for a while, a 6TB disk and a 3TB disk. The array was 3TB.
I powered down the NAS, took our the older one of the drives (the 3TB one), plugged in a new 6TB disk - what I wanted was for the new disk to sync with the old one and to then have a 6TB array.
This went as expected, but at the very end of the process the new disk reported it was a 'hot spare'.
I have investigated and see that I have "Current_Pending_Sector" and "Offline_Uncorrectable" are both set to 8 - could this be why the array won't rebuild properly?
Can anyone recommend a way to get the array working properly?
J
  • Mijzelf
    Mijzelf Posts: 3,013 image  Guru Member
    Yes. As soon as the rebuilding hits an unreadable sector on the source, it will stop the rebuild, and mark the target as spare.
    Here I wrote about how to solve that for Current_Pending_Sector. It should also work for Offline_Uncorrectable, but in that case the Reallocated_Sector_Ct will increase. So keep an eye on both Offline_Uncorrectable and Reallocated_Sector_Ct. If they keep increasing the disk is dying.
  • Mijzelf
  • That's great, thank you for the information.
    After I posted I rebooted the NAS, since then the array has rebuilt itself and now shows as healthy.
    I may have imagined it, but I think that somehow in the process what was disk1 and become disk2 and vice-versa.
    Does any of that make sense?
