DHCP options and login info
Hi !
I'm trying to configure a ZYXEL PM7300 for WAN connection.
It seems there is no possibility to setup a PPPoE encapsulation without credential (username / password) - is there a reason for this or a way to force it ?
Also, DHCP options are only available when I select IPoE, not PPPoE (which is not the case on my other router). Is it also on purpose ? Is there a way to go around ?
Thanks a lot for your help.
