Zyxel VMG3925-B10C Firmware Upgrade
I want to upgrade the firmware on my VMG3925-B10C router. The older firmware version is V5.13(AAVF.10)X4 and I want to upgrade it to V5.13(AAVF.18)C0.
I followed the instructions however "Firmware Upgrade" option is available in the "Maintenance" menu, I have also attached the screenshot of that interface please help me in this regard in upgrading my firmware as soon as possible. Thanks
Best Regards,
Usman
  • Peter2
    Peter2 Posts: 178 image  Master Member
    I think this :
    You have an "X" but not a "C" in the firmware name , so this might be a special branded firmware .
    You should try first to login over ssh if this is possible there is a chance to update original firmware .
  • Osmaan
    Osmaan Posts: 6
    @Peter2
    Hi Peter, Can you please explain this method briefly that how to upgrade via this method.
  • Osmaan
    Osmaan Posts: 6
    And what does the "X" mean in my current firmware version, is that router locked or not? Can you please guide me because I don't know much about it just guessing.
    Current firmware version= V5.13(AAVF.10)X4
