Zyxel NR5103: Suitable external antennas
Johnny_Z9
Dear all
The NR5103 5G modem provides the option to use up to four external antennas through 4 TS9 connectors supporting 698-4200 MHz frequency.
I was now looking for suitable external antenna products. Unfortunately there is no list of compatible products via Zyxel channels. I would appreciate if anyone could point to suitable products compatible with the Zyxel NR5103 (incl. any suitable antennas products by Zyxel) to maximize reception.
I guess only a 4x4 Mimo external antenna makes any sense (i.e. 2 port solution not being sufficient)?
Many thanks! :-)
Kind regards, J.
V1-01 with four 5 meters SMA (M) cables or V1-02 with N-type (F) connectors @ the antenna.
- 601 USG FLEX H Series
- 480 News and Release
