how to reuse SecuExtender IPSec VPN Client license key
Matteo73
Matteo73 Posts: 3 image  Freshman Member
Hi, I bought some years ago some windows licenses for SecuExtender IPSec VPN Client license key. I would like to know if it possible to reuse the license on a different PC becuase the original one has been dismissed.
I would also like to know if there is a way to understand which license has been used, and which one has not.
Could you please help me ?
Thank you
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Matteo73,
    Greetings.
    The Secuextender IPSec VPN Windows client was EOL on the 2nd of October.
    Here's the announcement for your reference:
    If you have requirement for the SecuExtender, you can consider to purchase the new license from Zyxel Marketplace.
    Thanks.
    Ivan
  • Matteo73
    Hi Ivan,
    I see in the post you sent there is an option to "-Yes, there is a license key swap program available where customers can exchange their unregistered lifetime key for a 3-year subscription key."
    Could you please give me support for this exchange ?
    Thank you
  • Zyxel_Ivan
    Dear @Matteo73,
    Greetins.
    Sure, I'm happy to help you to exchange the key.
    Can you provide the license key through the PM?
    So that I can check whether the license has been used before.
    Thanks.
    Ivan
Service & License Help Center
