Port Issue
Hi @Bolzy
Since your device is FWA510, which is a Nebula device, I assume you are using it with the Nebula control center. That's why I was asking for the organization's name and the privilege.
Please go to Help (identified by a question mark icon at the upper right corner of Nebula portal) > Support Request > Zyxel support Access to enable and save.
In addition, since this post is different from your problem, please check the private message I sent to you. I will help to check your problem via the private message.
Zyxel Melen1 -
I have tried to go there but the button support request it'not able.
Hi @Bolzy ,
To assist you efficiently with the issue of not being able to open ports 80 and 443, could you please provide us with the model's name of your device? Additionally, a photo of the front of or back of the device with the label would be very helpful. This information will enable us to offer prompt and accurate support.
Zyxel_Judy
Hi the model name is DX5401.
I think that the operator Windtre had force the closure of the Port inside the firmware, could be that ? Do you think you can say me how to open It ?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
