NSA320 Firmware upgrade
gingono
gingono Posts: 5
edited January 2024 in Personal Cloud Storage
Hello
I tried to upgrade my NSA320 with a firmware from 2011 (4.01) but the NSA did not accept the firmware 4.7 (470AFO0C0.bin) or 4.6.
What is the problem?
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    I believe the firmware may be too outdated.
    I agree with that. The first firmwares for the 320 were OABI, while the later ones (4.40+?) were EABI. I can imagine the scripts needed for the conversion was only in the first EABI firmware.
    Here you can find some older firmwares.
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    May need to attempt upgrading to several earlier versions first, progressing version by version until we reach the latest one.
    I've searched for alternative firmware on the internet, but it appears there are no resources available.
  • Yes, I also searched for driver version 4.21 or earlier, but with no success.
  • Mijzelf
  • Great! Where you found this page? Thanks a lot.👍️👍️👍️👍️
