Ztp is already enabled. Please report to administrator for troubleshooting
  • smb_corp_user
    smb_corp_user Posts: 172 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Sorry for not posting sooner. I must defer to the ZyXEL team members for a solution to this issue.
  • Marcointegrated
    Marcointegrated Posts: 21 image  Freshman Member
    ok, I and the other user are waiting for updates
  • Dennis_aE
    Dennis_aE Posts: 2 image  Freshman Member
    I am experiencing this issue as well. Please provide us with a resolution.
  • Good morning,
    I am also in the same situation. Can we deactivate the ZTP via the CLI and return to the WebGui interface?
    Maybe go back to an old configuration?
  • smb_corp_user
    There are some other pages outlining how to deal with the ZTP issue. See for example this Google search result:
    set system ZTP disable
  • Marcointegrated
    But to be able to disable the ZTP is a procedure that must be carried out on the switches or on the firewall? On the guide you sent, it looks like this.
  • Marcointegrated
    Can this configuration be valid to insert into the putty console for the zyxel vpn 100 firewall?
  • does not work
  • Dennis_aE
    Is it true that ZTP is available when the Zywall is in SD-WAN mode(VPN100 user guide)? If that is true then does that mean that my Zywall VPN is not standalone anymore and is in SD-WAN mode?
    Then the only way to go back to being standalone is by factory resetting my router?
    "Note: If your ZyWALL VPN is in SD-WAN mode and want to return it to standalone mode, you
    need to reset the ZyWALL VPN to the factory defaults using the reset button (see the
    Troubleshooting chapter)." - Section 1.2 SD-WAN Mode of the VPN100 User's guide version 5.37
