Ztp is already enabled. Please report to administrator for troubleshooting
Hello @Marcointegrated @Proxima
We're aware of this issue and have figured out the solution, please provide remote SSH via private message, and I will access the device for further action, thanks.1 -
To be able to access via ssh you need to access the VPN on our network with the ZyWALL SecuExtender application. I can provide you with the login server and username with a temporary password, then I can give you the address to log into ssh. I need your e-mail address to be able to insert it into the domain controller, once logged in you can validate the 2fa within 5 minutes and you will be inside our network.
@Marcointegrated @Proxima it's done. Please let me know if anything happens, thanks.
To solve this issue, please refer to the article below, thanks.
Thank you! But what do I need to do if I have this message:
PS C:> ftp 192.168.10.1ftp: connect :Connection refused
I have no physical access now to this device and connect now to it via ipsec.
UPD: подключившись по SSH для включения FTP сервера нужно выполнить
configure terminal
ip ftp server0 -
FTP connection was refused, SSH not connecting, console cable not connecting… what to do?
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
