Zyxel EX3301-T0
rycket
in Home Router
Why can't I upgrade formware to the version found in the files EX3301-T0_5.50(ABVY.4)C0 ?
My current formware version is V5.50(ABVY.3.1)I0
Firmware it skould be :)
The message I receive is
Image uploading failed. You may press 'Cancel' to upload another firmware image file, or press 'OK' to reboot to recover normal operation.
You have a special branded firmware from your ISP so it dont works , and if your contract is actual with this ISP you may have no right to upload this original firmware at least you should contact your ISP before . Maybe its owned by your ISP too ?
Otherwise you can try to upload the original firmware via ftp like this :
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 510 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
