[NEBULA] how do I configure a VPN network to access from laptop or cell phone?
Hi all,
I'm looking for a way to be able to let laptop/phones to VPN back to the network (to access internal webpage download files etc.)
I dont know the term, just know its a VPN way back to the local network. Anyone know how to do this?
Wayne
Wayne
Do you mean "L2TP over IPSec VPN"?
L2TP VPN may allow remote client to access internal resources. Most important of all, both laptop and smart phones support L2TP VPN by default.
I've never used Nebula devices as a L2TP VPN server so I cannot give you further information. Sorry about that.
@WaYne, Welcome to Zyxel Nebula forum, if you would like to setup a VPN network to access laptop or mobile phone, you can refer to the terminology of L2TP over IPSec VPN as @JCHEN's mentioned that allows remote users to access internal networks.
Our NSG series supports L2TP over IPSec VPN as well and there is more information about How to setup L2TP VPN client connection with Authentication Server? in FAQ > Configurations for your reference. Hope this is useful to you.
Zyxel Nebula Support
Okay, i got the point.
I've tried the steps from FAQ, trying to build the radius server for the first time is a bit annoying.
But since there is cloud authentication function on there, it seems not possible to authenticate through cloud authentication? why is that?
Wayne
Hi WaYne
We will offer this option of VPN user through nebula cloud authentication on phase II soon. Please stay tuned for the updates.Zyxel Nebula Support
I still can not get Nebula L2TP Cloud Auth to work with my L2TP over IPsec clients, standard native Android VPN on phones and tablets and Standard Native VPN on Windows clients. why is this? Both client types worked well with Zyxel USG device on both L2TP over IPsec for Android and L2TP over IPsec and SSL VPN for windows. SSL VPN is completely missing on NSG, It's quite frustrating when I updated an entire SMB network with only 2 year old zyxel devices for nebula devices to make it all easier/faster and create a better overview. And then it turns out that completely basic things do not work or are missing, it's almost like Nebula is a downgrade compared to former Zyxel products. Sorry for the negative sounding comments.
Hello @Mr_DJ
Welcome to Nebula community!!
Since you mentioned about the same setting on USG can work but not on NSG, hence I'll help out to troubleshoot, please check the private message.1 -
Hi @Mr_DJMr_DJ said:I still can not get Nebula L2TP Cloud Auth to work with my L2TP over IPsec clients, standard native Android VPN on phones and tablets and Standard Native VPN on Windows clients. why is this? Both client types worked well with Zyxel USG device on both L2TP over IPsec for Android and L2TP over IPsec and SSL VPN for windows. SSL VPN is completely missing on NSG, It's quite frustrating when I updated an entire SMB network with only 2 year old zyxel devices for nebula devices to make it all easier/faster and create a better overview. And then it turns out that completely basic things do not work or are missing, it's almost like Nebula is a downgrade compared to former Zyxel products. Sorry for the negative sounding comments.
It's quite easy to set this up.
Once you turn this on and create VPN user in Cloud authentication.
It's done.
How about share your setting to us?
Regards,
David0 -
Earth and others
It's all fine enough. And of course, I've made the settings that you show and tried with them before I write here and it still does not work. But now Zyxel support has gained access to the NSG where I have the problem, so we need to see if they find out what's wrong.And to those who could read this, I do not need more answers here.
Best regards
\Mr_DJ0 -
Thank you very much to @Nebula_ChrisThat was just the information I needed to get it all running.WOW what good and quick help.Now I'm not a second to doubt that the choice of Zyxel products is just right :-)Best regards
Mr_DJ2 -
- 441 Beta Program
- 293 Service & License
- 461 News and Release
