Multicast traffic filtered by NWA50AX AP
Stesso problema con AP90X PRO, viene filtrato il pacchetto multicast da parte dell'ap e di conseguenza non funziona più Airprint (non stampa da dispositivi IOS).
Se sostituisco l'AP con un altro modello (es. 1123) tutto funziona regolarmente con la stesso tenant.
News?
Hi @DavideASN ,
The AP facilitates packet forwarding and is not designed to filter packets.
To ensure successful communication between your iOS device and printer, verify that both devices are connected to the same SSID (Wi-Fi network) provided by the NWA90AX PRO.
Once confirmed, please execute the CLI commands mentioned in this comment and share the results with us. This will enable us to identify the source of the issue more accurately.Additionally, for comprehensive support, we recommend enabling Zyxel support and share with us the MAC address of iOS device.
Zyxel_Judy
Was a root cause and solution ever identified for this issue? I have the same problem with multicast traffic being lost by my NWA50AX.
I have my NWA50AX connected via Ethernet to my broadband router, with both devices broadcasting the same SSID for a single home network throughout my house.
When connected directly to my broadband router (either wirelessly or over Ethernet) I can discover mDNS services broadcast by other devices on my network, but when switching to connect wirelessly to my NWA50AX, no mDNS services are visible any more, suggesting the NWA50AX is filtering them out.
Hoping for a quick solution, many thanks!
[UPDATE: As no response here, I've made a separate post here]
- 588 USG FLEX H Series
- 477 News and Release
