How to use Antenna ports in Nebula FWA510 ?
Hello everyone
I am using zyxel fwa510 and living in an area with 4G only ...and the 4G signal is poor.
The router has 4 ts9 external antenna ports and I need your help to choose which pair of ports is for 4G (band 1 2100 mhz and band 3 1800 mhz only are available here).
I am using Kaser Panel V3 antenna mimo 2x2 (two cables out of the antenna).
I need your kind help 🙏
Hi @Fadhil ,
The TS9 connectors are designed to support frequencies ranging from 698 to 4200 MHz. In your specific circumstance, you can connect an antenna to any of the FWA510's external antenna ports.
Zyxel_Judy
Hi @Fadhil ,
Zyxel_Judy
Hi @Zyxel_Judy
Thank you for your explanation.
But I have seen in multiple forums that the 4 external antenna connectors are not the same..two of the them for 5G main and 4G main and the other two are for 5G and 4G diversity.
But no one could confirm which pair is for 4G main and diversity (1 and 2 ? 1and 4?)
Where port number 1 is at the top and 4 is at the bottom when looking at the router from the back.
I need your kind help to confirm which pair I plug my ts9 connectors to , to get 4G signal (here we have 4G bands B1 and B3 only if it matters to you when you decide).
Looking forward for your Reply 😊
Hi @Zyxel_Judy
I wonder whether it is normal or not for Zyxel support employees not to answer their customers .
I have Zyxel Nebula FWA510 and I asked to which connectors (numbered from 1 to 4 in the included image)should I plug my external antenna cable ts9 ends (only 2 cables) when I am using 4G bands 1 and 3 only (band locking 4G B1 and B3).
But no one is giving me an answer , whom should I ask if the manufacturer neither mentions that in user guide nor answers you questions ❓
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
