Lte7490-m904
Matita
Non riesco ad aggiornare il firmware qualcuno sa aiutarmi ?
Hi @Matita, did you upload with the .zip file? If yes, please unzip it and use the "100ABQY7C0.bin" file to upgrade.
Zyxel Melen0 -
SI ho provato ma da sempre errore
Hi @matita,
We will suggest to upgrade the fw by connecting a PC.
Please try connect with a cable, login GUI and use the fw 100ABQY7C0 (can be downloaded in below link) for upgrading.
thank you.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
