VMG8623-T50B not getting full speed
idk12345
idk12345 Posts: 2 image  Freshman Member
edited October 2023 in Home Router
I have router Zyxel VMG8623-T50B and got 250mbit down/20mbit up plan, but when I try a speed test (rychlost.cz, speedtest.net, fast.com) i get only 100mbit/20mbit. Why could it possibly be? Also interesting thing to mention is when I open the System info, under Interface status in DSL, I get this:
Does it mean that the DSL port is getting those 200mbit?
Also I tried changing the firmware multiple times and resetting it but nothing helped. Also tried speed testing using Wifi and phone, but same issue there.
  • idk12345
    Also here are my firmware versions:
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited October 2023
    Hello @idk12345
    Welcome to the forum.
    Yes the figures under DSL in your first screenshot shows that your router is getting the speeds you want as the line rate for your DSL connection.
    Are you doing the speedtest over WiFi or Ethernet? If WiFi, then 2.4GHz band or 5GHz band? Also if WiFi, how far are you away from your router and does your device running the speedtest support fast speeds like 802.11ac?
    If you are using WiFi, then the settings under Network Setting → Wireless→ Other could have an effect on your speeds, see below screenshot from the user guide at https://spdl.zyxel.com/VMG8623-T50B/user_guide/VMG8623-T50B_1.pdf
    Many questions. Please let us know what you think.
    Kind regards,
    Tony
  • Mrmoy
    Mrmoy Posts: 4
    Hello. I have download and upload 1gb. But im not getting full speed. I am only getting around 300 to 400 mb. Is there anything i could do the speed up .
    Warm regards
  • Mrmoy
    Mrmoy Posts: 4
    VMG8623-T50B router
  • tonygibbs16
    edited February 2024
    Hello @Mrmoy
    I cannot see your screenshot as it says 404 for me.
    What firmware version are you on please? and how are you doing the speedtest?
    If you are doing the speed test by WiFi, then the WiFi settings under Others that I mentioned in my October 2023 post could slow the speedtest down because not all of the WiFi standard versions go fast.
    from https://en.wikipedia.org/wiki/Wi-Fi
    So if you are speed testing using WiFi, then other settings and other WiFi devices can slow it down.
    - maybe make sure that you are testing in 5GHz band and that the router is set-up to use 802.11ac only…and not a mixed mode.
    Kind regards,
    Tony
  • Mrmoy
    Mrmoy Posts: 4
    Firm ware V5.50(ABPM.7)C0
    I go to fast.com to check speed.
    Yes I have test the speed on 5g
    Regards
  • Mrmoy
    Mrmoy Posts: 4
    How do I set-up to use 802.11ac only
  • tonygibbs16
    Hi @Mrmoy
    Use the Web Configurator and then select Network Setting then Wireless and then Others to set 802.11ac against the 5GHz band WiFi.
    The 802.11ac is under Wireless → Others as an advanced wireless setting as the 802.11 Mode against 5GHz band:
    Kind regards,
    Tony
