How to set up Android 14 for L2TP via IPSec for ATP100
We use VPN on ATP100 using L2TP (IPSec). Everything still works on Android 12 and older. L2TP (IPSec) is no longer an option on Android 13 and 14. On Android 13 and 14, there is only IKEv2/lPSec MSCHAPv2, IKEv2/lPSec PSK and IKEv2/lPSec RSA.
Which option for Android 13/14 should we select from the image?
Since NSG also provides the IPSec VPN function, you can use the StrongSwan App to connect.
Zyxel Melen0
You might have to setup without the use of quick start
setup a Phase 1 Settings in VPN gateway with the following
show advanced settings
IKEv2
Domain Name / Ipv4 0.0.0.0
set Pre-Shared Key
Phase 1 settings
AES128 SHA256
key group DH14 (one some phones needs to be set higher)
Phase 2 Setting VPN connection
Remote Access (Server Role)
select VPN gateway you made
Local policy 0.0.0.0
Configuration Payload setup IP range for VPN
Phase 2 Setting
AES128 SHA256
PFS DH2
set zone for the VPN
Hi @JanBab,
Select "IKEv2 IPSec Client" and follow the guide in this FAQ to install StrongSwan on Andorid.
When I start the setup wizard for "Remote Access VPN Setup - IKEv2" via Quick Setup, the message appears: "The Rule has been modified before. Do you want to change the VPN rule?
Click Yes to change VPN rule through Wizard.
Click No to exit the Remote Access VPN setup."
Will the rule also change for "L2TP over IPSec Client"?0 -
Is this possible to do With the ZyXEL NSG50 (only Nebula konfig)
The customer have a new Android 14 with removed L2TP settings0 -
Zyxel Melen0
- 603 USG FLEX H Series
- 481 News and Release
