NAS540 RAID1 to RAID5 migration incomplete
I have a NAS540 device and it was configured in RAID1 on 2 4TB drives. after adding the 4TB drive I started migrating to RAID5. after reaching 100% (and it took 2 days) and after the next 24 hours, the spinning circle is still shown and the process has an incomplete status. On the Hard Disk tab, three disks are described as forming a RAID5 array. What to do now ?
Regards
Rafalg
Login over ssh, and execute
cat /proc/mdstat
to see what the kernel thinks about the conversion. I think the firmware daemon just missed the 'operation completed' signal.
cat /proc/mdstat
Before restarting, I logged in to the console via SSH and checked the matrix status:
Everything seemed to be OK
~ # mdadm --detail /dev/md2
/dev/md2:
Version : 1.2
Creation Time : Mon Feb 1 14:08:39 2016
Raid Level : raid5
Array Size : 7805773440 (7444.17 GiB 7993.11 GB)
Used Dev Size : 3902886720 (3722.08 GiB 3996.56 GB)
Raid Devices : 3
Total Devices : 3
Persistence : Superblock is persistent
Update Time : Fri Feb 16 10:32:02 2024
State : clean
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : NAS540:2 (local to host NAS540)
UUID : 4b8110cb:f1fd3ffa:0dc51f0a:4cab2bc2
Events : 17127
Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
1 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
After the restart, however, the system performed some other operations and after over an hour the system recovered and is in the RAID5 configuration. Nevertheless, thanks for your reply
Regards
R.G.
- 601 USG FLEX H Series
- 480 News and Release
