SecuExtender IpSec tunnel to USG Flex 200
Installed SecuExtender 7.7.40 on a notebook and tried to create an IPSEC tunnel to the USG FLEX 200 firewall.
It does not work with the wizard on USG and SecuExtender, have therefore tried to manually set up a VPN tunnel, even if the parameters are the same on USG and SecuExtender, it does not work.
It works fine on another PC with an earlier perputual version of secuextender.
Does anyone have a guide?
I do not remember the specifics, but in theory it could possibly be a case of the current firmware on the USG not supporting communication with your new version of the SecuExtender.
Hi @KimKjelmann
Please refer to this FAQ article Remote Access VPN Wizard for SecuExtender IPSec and Non-SecuExtender IPSec VPN Clients , thanks.
Zyxel_Jeff
Unfortunately I get a server error.
Port 443 is NAT to server behind firewall, have tried to NAT other port to firewall's internal IP, no luck.0 -
Hi @KimKjelmann
OK, noted. Alternatively, could you import the .tgb file into the SecuExtender for an alternative solution? It shall be working for you. Thanks.
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 299 Service & License
- 486 News and Release
