Firmware not available for EX3301-T0
Hi @Peter , unfortunately existing status ftp connection is imposible.
Hi @tonygibbs16 , I understood this method but I think the bootbase file (304tuj.bm) referred in this page for old model zyxel router. Can it be completely damage the router?
Hi @Spdif
Probably best to follow the approach used for the Zyxel PMG5617GA mostly, and only the older post when referred to from the newer thread.
Kind regards,
Tony
This would have been the easier way :
»»» May be you can try to disable the parameters "modelcheck" and "fwidcheck" via ssh to allow firmware upgrade when the cause is e.g. special ISP firmware version over web gui like below :
Download firmware is available and manual Upgrade via webgui is possible so this is the best solution …
@Peter2, unfortunately, actually I don't have webgui. Completely lost it. First of all, I thought of updating from webgui, but this option was not available in ISP fw.
@tonygibbs16 PMG3617GA method is a bit complicated to me. I will try to understand in a quiet time.
Thank you.
This is bad . Now its happend like this and its to late but there is a way to acivate local ftp acces of the device . You can change the backup file and restore it afterwards .
Change this section like this an then you can access via cli and ftp over local LAN :
"Name":"FTP",
"Enable":true,
"Protocol":6,
"Port":21,
"Mode":"LAN_ONLY",
"TrustAll":true,
"WANPort":-1,
"OldMode":"LAN_ONLY",
"RestartDeamon":true,
"LifeTime":20,
"BoundInterfaceList":"",
"RedirectHttps":false
},0
- 439 Beta Program
- 2.8K Nebula
- 206 Nebula Ideas
- 522 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.5K FAQ
- 98 Security Highlight
