How to make apple airprint work on an lte 3316 dual-band router?
bhliedtke
bhliedtke Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
On the old lte3311 mono-band router airprint worked fine. On the new lte3316 I can reach the GUI of the printer from a macbook and an iphone alright but when I want to print it says no printer available. I have turned off the 5MHz band to force all devices on the 2,4 MHz band, but that seems not to solve the problem. What is the solution?
  • Miaa
    Miaa Posts: 28 image  Freshman Member
    First Anniversary
    Hi bhliedtke , it seems some WiFi problem on iOS 15 recently , if you encountered problem after the update, you might need install next new one to see whether fix the problem.
  • tonygibbs16
    tonygibbs16 Posts: 977 image  Guru Member
    Hi @bhliedtke
    I wonder if the apple airprint support instructions might help you, see https://support.apple.com/en-us/HT201311
    I have not used Airprint myself.
    Kind regards,
         Tony
  • LTE 3316 M640.
    What does it mean when the bar light is red or green.
  • tonygibbs16
    edited February 2024
    Hello @Gerhardt
    Welcome to the forum, if you mean the LTE/3G signal strength bars, then it has the following meanings by colour:
    Kind regards,
    Tony
