How to make apple airprint work on an lte 3316 dual-band router?
bhliedtke
On the old lte3311 mono-band router airprint worked fine. On the new lte3316 I can reach the GUI of the printer from a macbook and an iphone alright but when I want to print it says no printer available. I have turned off the 5MHz band to force all devices on the 2,4 MHz band, but that seems not to solve the problem. What is the solution?
Hi @bhliedtke
I wonder if the apple airprint support instructions might help you, see https://support.apple.com/en-us/HT201311
I have not used Airprint myself.
Kind regards,
Tony0 -
LTE 3316 M640.
What does it mean when the bar light is red or green.
Hello @Gerhardt
Welcome to the forum, if you mean the LTE/3G signal strength bars, then it has the following meanings by colour:
Kind regards,
Tony
- 441 Beta Program
- 292 Service & License
