ATP200 issue - Trafic blocked
I have an issue with ATP200, this firewall blocks mostly all the trafic even I don't have any active security rules activated. I didn't touch any rules, it was working fine before and since a couple of days I have these in my logs :
2024-02-20 16:24:11Security policy192.168.1.14856671216.239.32.117443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP2024-02-20 16:24:11Security policy192.168.1.14856645216.58.212.163443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP2024-02-20 16:24:11Security policy192.168.1.1485667252.168.112.66443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP2024-02-20 16:24:11Security policy192.168.1.1485667313.89.179.11443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP2024-02-20 16:24:11Security policy192.168.1.1485667252.168.112.66443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP2024-02-20 16:24:11Security policy192.168.1.14856670142.250.185.78443Rule name=SF_CLIENT_POLICY_7b0235f4-7d36, TCP Port 443, DROP
These are the security default rules :
My firmware version is : V5.37(ABFW.1)
Please advice. Thank you.
  • smb_corp_user
    smb_corp_user Posts: 170  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    (copy-pasting your log output for easy reading)
    Log entry Date
    Log Time
    Source policy type
    Source address
    Source port
    Destination address
    Port
    Rule descriptor (name, type, number)
    Rule identifier
    Rule port type
    Rule action
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56671
    216.239.32.117
    443
    b0235f4-7d36
    TCP Port 443
    DROP
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56645
    216.58.212.163
    443
    b0235f4-7d36
    TCP Port 443
    DROP
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56672
    52.168.112.66
    443
    b0235f4-7d36
    TCP Port 443
    DROP
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56673
    13.89.179.11
    443
    b0235f4-7d36
    TCP Port 443
    DROP
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56672
    52.168.112.66
    443
    b0235f4-7d36
    TCP Port 443
    DROP
    2024-02-20
    16:24:11
    Security policy
    192.168.1.148
    56670
    142.250.185.78
    443
    b0235f4-7d36
    TCP Port 443
    DROP
  • smb_corp_user
    Looking at your last security policy rule entry, it looks like all traffic is blocked:
    Action
    Protocol
    Source
    Destination
    Port dst
    Schedule
    Description
    Deny
    Any
    Any
    Any
    Any
    Always
    Default rule
    I am not 100% sure, but it looks like there is a default rule to block all traffic. Maybe it needs to be modified to block only unwanted port traffic or IP addresses?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 944  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Fanta88 ,
    Greeting Forum,
    Please kindly provide your org name by Private message also grant zyxel support access.
    We would do the check.
    Thank you
  • Zyxel_Kevin
    Hi @Fanta88 ,
    I think you already open a ticket to local support.
    We're checking on it.
    Thank you
  • Zyxel_Kevin
    Hi @Fanta88 ,
    We already solved the issue
    Please kinldy check if those clients works.Thank you
