alternate failed log in
Hi @PRL
Thank you for providing the model of your switch. The GS1920-8HP indeed has both RESET and RESTORE buttons on the front panel. To initiate a factory reset, it's crucial to press and hold the RESTORE button for more than 7 seconds until the PWR LED turns amber. This action will revert the switch to its default settings. Please note that simply pressing the RESET button will only result in a reboot of the switch.
After performing the factory reset, if you still encounter difficulties accessing the switch with the default IP, I recommend following the troubleshooting steps outlined by @Zyxel_Judy in this thread:
Please keep us updated on your progress, and don't hesitate to reach out if the issue persists. We're here to assist you further.
Kay
Hi @PRL
To better assist you, could you please share with us the model of your switch? Additionally, to restore the switch to its factory default settings, kindly press and hold the RESTORE button for more than 7 seconds. This should restore the switch and allow you to log in using the default credentials (admin/1234).
Kay
It is the GS1920-8HP model. I have already MANY times pressed the reset button - that does NOT get me in using default credentials.
button - that does NOT get me in using default credentials. As I mentioned in a separate post, when I try to log on using the default IP for the switch, I get the login screen for my router. Either way, I have never been able to log into my switch.0 -
Hi @PRL
Kay
OK, I was pressing the wrong button. Now I have been able to access the Switch and changed the default password. Now I want to set up a VLAN so that several computers can see what is on the other and exchange information, share printer, etc. I was reading the manual on VLANs and I can't make heads or tails as to what I need/which type/what set-u if any is needed. I'm a novice-minus when it comes to networking. If it matters I use Linux 99% of the time and once in a blue moon MS. There are no other persons - just me and various computers and devices, however I want the entire system VERY secure from the outside, but don't need passwords internally. Where do I go next in this journey in dark caves?
Hi @PRL
We noticed that you rejected the answer regarding the VLAN configuration tutorial article we provided. Did you encounter any difficulties while attempting to set up the VLAN?
If so, please provide us with more details about the devices connected to your switch and which VLAN you would like each device to belong to. With this information, we can offer more tailored guidance to assist you effectively.
Looking forward to hearing from you soon so we can provide further assistance.
Kay
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
