NR5103EV2 USB SHARE Storage size
AllyR
I have the 5G router, when I connect a 128Gb flash drive to the usb port, it is visible in the USB share tab on network router page, however when I connect a 2Tb drive it is not recognised. What is the size limit of the attached share drive?
Hi @allyr,
I don't think it's the size limit caused the difference, the reason should be the format.
It only supports FAT32, other is not supported.
thanks.
- 603 USG FLEX H Series
- 480 News and Release
