Remote connection Flex 200
Hi @Darren,
If the device is deployed as nebula mode, you can only configure on nebula portal only. If you need full features as on-premises mode, you can consider using Cloud Monitoring Mode.
I don't think you can….
I don't see why its not possible either however just thats how Nebula was done…
Hi @Darren,
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
