New SIM card not working on LTE3301-M209
Xharli3
I've just switched for a new SIM card due to new internet supplier and its not working at all. All I get is flashing red indicator.
Can it be that the new card is an actual phone SIM and not a data SIM? Can the LTE3301 not handle the phone SIMs?
Answering my own question: You need to enter the pin code for the new SIM card in the router settings. Log into your router, see relevant manual, enter pin code, done.
If you can't log into your router, due to chosing new password well into your drinks and forgetting said password, you need to reset your router. But don't worry, once this is done you will have solved the problem within five minutes. As I did.
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
