How to connect 4G antenna ports in Zyxel FWA510?
Hello everyone
I am using zyxel fwa510 and living in an area with 4G only ...and the 4G signal is poor.
The router has 4 ts9 external antenna ports and I need your help to choose which pair of ports is for 4G (band 1 2100 mhz and band 3 1800 mhz only are available here).
I am using Kaser V3 antenna with two ts9 ends.
Thank you
les différentes prises
les sélectionner en conséquence :Port
ANTO(principal)
Fréquence
703 MHz-4200 MHz
Q⑦
Port
DRX
Fréquence
703 MHz-4200 MHz
Port
MIMO3
Fréquence
1710MHZ-4200MHz
Port
MIMO4
Fréquence
1805MHZ-4200MHz
Typically, the ports are labeled with LTE band numbers, and you should choose the ones corresponding to the bands you want to boost. In your case, for 4G with Band 1 (2100 MHz) and Band 3 (1800 MHz), you'll need to connect your Kaser V3 antenna to the ports that support these bands like poly track
-1 -
Hello @Fadhil and everyone.
Zyxel say in the following linked post to connect to all 4 but provide more details also:
If you cannot do all 4, e.g. because the Kaiser v3 has only two connections according to https://www.amazon.co.uk/Omnidirectional-698-2700MHz-Connector-Compatible-Receiving/dp/B08T5YBLZM then might I suggest connecting the top 1 definitely (called Ant0(main) ) and then try the other 3 in turn to see which works the best…
Kind regards,
Tony
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
