NAS540 Volume status shows resyncing
Hi
I m using NAS540(4 disks, raid5) for years and did not make any change. When I was copying file(SMB) suddenly I could not access my share drive. As I checked, it shown resyncing in Storage Manager > Volume > Volume status.
I don't know why it started to resync, I did not do anything.
I'm not sure the storage is degraded or not. It shows "Storage Status: Warning" at home screen but in Storage Manager > Overview, it shows "Healthy" and Volume on RAID shows no degraded.
I also check S.M.A.R.T and 4 HDD status are green but when I click on Disk3, it shows BAD and Status: Danger with 5 Reallocated_Sector_Ct (detail below)
I m not sure because of DISK 3 or not but the status showing green. Should I change disk3? Can I change it with 1TB disk? (I'm using all 2 TB disk and I only use around 60% of volume, so I m considering to reduce my HDD size.)
ItemValue
Power_On_Hours | 8685 hour(s) |
Spin_Retry_Count | 0 |
Reallocated_Sector_Ct | 5 |
Model Family | Western Digital Caviar Green (AF) |
Device Model | WDC WD20EARS-19MVWB0 |
Serial Number | WD-WCAZA4120898 |
LU WWN Device Id | 5 0014ee 25ad78d8d |
Firmware Version | 51.0AB51 |
User Capacity | 2.00 TB |
Sector Sizes | 512 bytes logical, 4096 bytes physical |
ATA Version | ATA8-ACS (minor revision not indicated) |
SATA Version | SATA 2.6, 3.0 Gb/s |
Local Time | Wed Feb 28 20:06:38 2024 GMT |
SMART support | Available - device has SMART capability. |
SMART support | Enabled |
S.M.A.R.T - Disk3
OverviewS.M.A.R.T InfoIDAttributeValueWorstThresholdTypeUpdatedWhen
FailedRaw Data
1 | Raw_Read_Error_Rate | 200 | 200 | 051 | Pre-fail | Always | - | 0 |
3 | Spin_Up_Time | 243 | 168 | 021 | Pre-fail | Always | - | 2841 |
4 | Start_Stop_Count | 099 | 099 | 000 | Old_age | Always | - | 1930 |
5 | Reallocated_Sector_Ct | 200 | 200 | 140 | Pre-fail | Always | - | 5 |
7 | Seek_Error_Rate | 200 | 200 | 000 | Old_age | Always | - | 0 |
9 | Power_On_Hours | 089 | 089 | 000 | Old_age | Always | - | 8685 |
10 | Spin_Retry_Count | 100 | 100 | 000 | Old_age | Always | - | 0 |
11 | Calibration_Retry_Count | 100 | 100 | 000 | Old_age | Always | - | 0 |
12 | Power_Cycle_Count | 100 | 100 | 000 | Old_age | Always | - | 593 |
192 | Power-Off_Retract_Count | 200 | 200 | 000 | Old_age | Always | - | 504 |
193 | Load_Cycle_Count | 192 | 192 | 000 | Old_age | Always | - | 26448 |
194 | Temperature_Celsius | 105 | 095 | 000 | Old_age | Always | - | 45 |
196 | Reallocated_Event_Count | 197 | 197 | 000 | Old_age | Always | - | 3 |
197 | Current_Pending_Sector | 200 | 200 | 000 | Old_age | Always | - | 1 |
198 | Offline_Uncorrectable | 200 | 200 | 000 | Old_age | Offline | - | 0 |
199 | UDMA_CRC_Error_Count | 200 | 200 | 000 | Old_age | Always | - | 37 |
200 | Multi_Zone_Error_Rate | 200 | 200 | 000 | Old_age | Offline | - | 7 |
In itself a Reallocated_Sector_Ct of 5 isn't alarming. It is only a problem when it's growing fast. But it can cause a degraded array, and so can the Current_Pending_Sector of 1. The latter is mildly surprising. I'd expect that to be zero after a rebuild. (A Current_Pending_Sector is a sector which is physically fine, but has a wrong checksum, so the content is basically unknown. A read will cause an I/O error (which can cause a drop from the array), but after a write it's OK.)
When you have a decent backup I wouldn't worry about this disk, given the information you provided. (And you should have a backup. The box will fail, some day. And no, raid is not a backup.)
Not with raid5. With some manual work it is possible to shrink the array in a way that a 1TB member can be used, but then the remaining space is 50%.
Hi
Thanks for answering.
I'm thinking about the backup as you mentioned. I decided to use raid5 because thought it is backup but the maintenance fee is quite high. As I'm using only 60% of raid5 volume, I think 3TBx2 with raid 1 will be more suitable for my case.
But I still have 3 usable 2TB disks. Can I use 3TB disk to join this raid5 first? will it be working? Does it require any specific configuration? Later if 2TB disk fails, I will add more 3TB and change to raid 1.
Yes, you can without problems use a disk which is bigger than the disk to be replaced.
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 668 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 499 News and Release
- 96 Security Advisories
- 5K FAQ
- 89 About Community
- 111 Security Highlight
