Copy data from removed jbod disks
I had to remove 2x 2TB disks from NSA 325 due to possible hw error. The disks are intact without any failure. They were installed in jbod mode.
Is there any tool I can read the data with?
When I attached the disks via USB rack the volumes are there. The first disk seams readable with accessible file system but the second one has no any fs just the volume.
Any idea?
Best Answers
Alas the meaning of JBOD is different for different NAS brands. For a ZyXEL it means 'linear multi disk', which means that the different disks are glued together to one new virtual device. So your first disk contains the first half of the resulting volume, and the second disk the second half.
Now you can sort of read your first disk, because the header of the filesystem is on the first half, but the second starts in the middle. To read the volume you'll have to assemble the array.
BTW, the difference between linear multi disk and raid0 is that raid0 is chunked. The first 64k of the virtual disk is on disk 1, the second 64k on disk 2, the third on disk 1, … . This has as advantage that while reading/writing big files you can combine the throughput of both disks.
Is it possible to attach these volumes to the new NAS somehow?
Unfortunately not. The partition layout on the NAS series is different from the partition layout on the NSA series, so it's not recognized as a 'familiar' disk. But it is possible to assemble and mount the volume manually, and then it stays mounted till next reboot.
Indeed. You have got 2 linear array of 1 disk each.
So the commands to assemble and mount them could be
su mdadm -A /dev/md0 /dev/sda2 mkdir -p /mnt/myvolume mount /dev/md0 /mnt/myvolume mdadm -A /dev/md1 /dev/sdb2 mkdir -p /mnt/myvolume2 mount /dev/md1 /mnt/myvolume2
One more... I have got a NSA 326. Started the setup process with those 2 disks, but it says would like to create new volumes. I didn't let to do. But the NAS system is up.
Thx. So I need a system to let me in via ssh, now the factory system don't let me in.
Can I start a modded one from back USB ports?
? I don't understand the question.
You can use your 326 to read the disks. Start it without disks, and enable the ssh server. Check if you have ssh access. Shut it down, and insert the disks. Then start it up, login over ssh, and execute
su mdadm -A /dev/md0 /dev/sda2 /dev/sdb2
Now your array should be assembled to a virtual device md0. Then mount it:
You should be able to see your files with
find /mnt/myvolume
But it is also possible that the firmware dives in between handles the filesystem as an USB stick and moves the mountpoint. In that case you can see it in the webinterface and use it as a normal share.
My bad, finally found the ssh enable menu and the NAS let me in.
Try to do mdadm and the rest, will feed back.
Thx
(my last post disappeared…)
So, I faced with other difficulties after log in via ssh and tried suggested commands. Here is the result:
~ # mdadm -A /dev/md0 /dev/sda2 /dev/sdb2
mdadm: no RAID superblock on /dev/sdb2
mdadm: /dev/sdb2 has no superblock - assembly abortedDisk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xced5416bDevice Boot Start End Sectors Size Id Type
/dev/sda1 63 1028159 1028097 502M 8 AIX
/dev/sda2 1028160 3907024064 3905995905 1.8T 20 unknownPartition 2 does not start on physical sector boundary.
Disk /dev/sdb: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: dos
Disk identifier: 0xf1aeb40bDevice Boot Start End Sectors Size Id Type
/dev/sdb1 63 1028159 1028097 502M 83 Linux
/dev/sdb2 1028160 3907024064 3905995905 1.8T 20 unknownPartition 2 does not start on physical sector boundary.
Can you post the output of
su mdadm -E /dev/sd[ab]2
Of course yes. But there are some news.
I tried this:~ # mdadm --assemble --scanmdadm main: failedtogetexclusive lockonmapfilemdadm: /dev/md/NSA325:1has been startedwith1drive.mdadm: /dev/md/0_0 has been startedwith1drive.After that I succesfully mounted "NSA325" and "0_0" volumes and could list all the files on those. It seems i didn't make an array of the two disks but installed them individuals but JBOD types.
the mounted volumes can be acces with winscp, and I initiated succesfull download!
here is the outout:
~ # mdadm -E /dev/sda2
/dev/sda2:
Magic : a92b4efc
Version : 0.90.00
UUID : 2df9b15b:f7eaf4b3:8b7f4c77:b216125d
Creation Time : Mon Jan 6 21:23:55 2014
Raid Level : linear
Raid Devices : 1
Total Devices : 1
Preferred Minor : 0Update Time : Mon Jan 6 21:23:55 2014
State : cleanActive Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
Checksum : b23ab137 - correct
Events : 1Rounding : 0K
Number Major Minor RaidDevice Statethis 0 8 2 0 active sync /dev/sda2
0 0 8 2 0 active sync /dev/sda2
~ # mdadm -E /dev/sdb2
/dev/sdb2:
Magic : a92b4efc
Version : 1.2
Feature Map : 0x0
Array UUID : 54c231fb:f0ace46c:54ec7371:5b06bdee
Creation Time : Fri Dec 1 01:26:30 2017
Raid Level : linear
Raid Devices : 1Avail Dev Size : 3905993857 (1862.52 GiB 1999.87 GB)
Used Dev Size : 0
Data Offset : 2048 sectors
Super Offset : 8 sectors
State : clean
Device UUID : d963be84:b6a21e32:9754916f:1b46a9daUpdate Time : Fri Dec 1 01:26:30 2017
Checksum : 74161f4f - correct
Events : 0
Rounding : 0KDevice Role : Active device 0
Array State : A ('A' == active, '.' == missing)0 -
- 441 Beta Program
- 292 Service & License
